samfromco
Oct 10, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 01, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
onepiece
Nov 01, 2021Tutor
Original solution:
- FURRYe38Nov 02, 2021Guru - Experienced User
Are you noticing any DNS problems after this version is loaded?
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281 - dev70000Nov 03, 2021Guide
Thanks, I am also able to update using nmrpflash. thanks for the most awaited solution.
within few minutes i was able to update using nmrpflash. and now it updates using the nighthawk app as well.
- TurbodogToddJul 13, 2022Guide
nmrpflash worked for my router that was stuck on R7960P-V1.4.1.50_1.3.10.
- FURRYe38Jul 13, 2022Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
