samfromco
Oct 10, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 01, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
onepiece
Nov 01, 2021Tutor
Original solution:
Nov 02, 2021Guru - Experienced User
Are you noticing any DNS problems after this version is loaded?
Original solution:
