muratyigiter
Mar 01, 2025Aspirant
Re: R7960P stops working
I have the same router and the same problem. The router disconnects the internet frequently. I reset it to factory settings, but the next day or shortly after, it cuts the internet again until I rese...
- Mar 17, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Mar 01, 2025Guru - Experienced User
Does the top Internet LED turn AMBER when this happens?
Who is the ISP your connected with?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Is IPv6 enabled on the router?
As a suggestion, put a usb FAN under the router for additional cooling.
