muratyigiter
Mar 01, 2025Aspirant
Re: R7960P stops working
I have the same router and the same problem. The router disconnects the internet frequently. I reset it to factory settings, but the next day or shortly after, it cuts the internet again until I rese...
- Mar 17, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
muratyigiter
Does the top Internet LED turn AMBER when this happens? Leds white
Who is the ISP your connected with? LUS Fiber (Louisiana Lafayette Local utility system)
What Firmware version is currently loaded? No longer have new firmware for my router
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I am not sure but I guess ALCATEL
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. Yes good CAT6
Is IPv6 enabled on the router? No
As a suggestion, put a usb FAN under the router for additional cooling. The device is not warm
Mar 01, 2025Guru - Experienced User
What version of FW is loaded on the router now?
- muratyigiterMar 01, 2025Aspirant
Firmware Version
V1.4.4.94_1.3.56- FURRYe38Mar 01, 2025Guru - Experienced User
So when the router goes out, does this effect both wired and wireless connected devices?
Can you access the routers web page at all when this happens?
How many devices are connected to the router at one time?
What channels are you using on the router?
Any other features enabled on the router like Guest Network?
Try seet a different DNS configuration from ISP Auto detected. Use Cloudfare or Quad9.
Might try the router at a different location like a friend or family's place to see if problem follows.
- muratyigiterMar 02, 2025Aspirant
So when the router goes out, does this effect both wired and wireless connected devices? Yes all of...
Can you access the routers web page at all when this happens? Yes but I see "not connected"
How many devices are connected to the router at one time? 1 cable 16 wireless
What channels are you using on the router? Smart Connest + Auto
Any other features enabled on the router like Guest Network? No
Try seet a different DNS configuration from ISP Auto detected. Use Cloudfare or Quad9. Sorry, my Experiences don't include that :)))
Might try the router at a different location like a friend or family's place to see if problem follows. I can't' because my current relatives have a little bit of hacker phobia
BUT,
Last month I added a powerline set for to expand, now I cancelled it. I will look, if problem don't come again I will understand guilty that power line set
