muratyigiter
Mar 01, 2025Aspirant
Re: R7960P stops working
I have the same router and the same problem. The router disconnects the internet frequently. I reset it to factory settings, but the next day or shortly after, it cuts the internet again until I rese...
- Mar 17, 2025
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
muratyigiter
Mar 14, 2025Aspirant
I removed the powerline adapter when it last stopped working, and it never stopped again. I guess the adapter was guilty.
thanks a lot for your help.
Mar 17, 2025Guru - Experienced User
Enjoy. 📡
