Sharonshriki
Apr 18, 2022Follower
R8000 cant reach 1000mb
Hi all, i have upgraded to 1 gigabit fiber and connected a cat 5e frome the fiber to eth receiver. When i test the speed from the router i can only download 230 mb. In netgear document it written that...
nnagreg
Apr 18, 2022Apprentice
Here are a couple of ideas for you:
#1 Check to ensure that you are using the SPEEDTEST from your ISP (Internet Service Provider). I'd suggest searching or looking up your specific ISP speed test, this can make a significant difference.
And as Recommended in the previous response
#2 Try using the Built-in SPEEDTEST under the menus -> BASIC -> Dynamic QoS -> TAKE a SPEEDTEST
Hope this helps!
- FURRYe38Apr 18, 2022Guru - Experienced User
There is a known issue with the built in speed test on some NH routers not reporting accurate results.
Recommend using Ooklas installable speed test app on a wired PC:
