KStevenson
Apr 15, 2022Tutor
R8000 Connectivity with 2 Routers
Hi Team X6 R8000 router Firmware V1.0.4.84_10.1.84 Internet speed test "Good", phone app shows 302.24 down, 23.91 up Panel lights: Power: Solid white Internet: flashing white 2.4: solid white/...
Apr 15, 2022Guru - Experienced User
How was the AP configuration set on the 2nd Router? Dynamic IP or Static IP? Static IP is recommended so you know where to access the 2nd routers web page at and the IP address doesn't change.
How are the wifi channels configuredon each? They should be far apart between each unit, router 1 at channel 1 and 40, AP mode router at channel 11 and 149 thru 161.
KStevenson
Apr 15, 2022Tutor
FURRYe38 wrote:How was the AP configuration set on the 2nd Router? Dynamic IP or Static IP? Static IP is recommended so you know where to access the 2nd routers web page at and the IP address doesn't change.
I could be wrong but i'm pretty certain we didn't make any of those changes. I also cannot access my second router now to look at anything. I'll see what i can do between now and tomorrow. I'll try to get back to you. THANKS A MILLION FURRE38.
- FURRYe38Apr 15, 2022Guru - Experienced User
Look at the 1st routers connected clients page to see if the 2nd router appears there and check for a different IP address. Could have changed.
- KStevensonApr 15, 2022Tutor
FURRYe38 wrote:Look at the 1st routers connected clients page to see if the 2nd router appears there and check for a different IP address. Could have changed.
By connected clients you meant attached devices (FYI for future readers). Yes, that is right!!! There was a different IP Address and I was able to login to the router. Both of these routers say 48 devices are connected. That if 4 short of the typical total.
Let me go back to your previous questions:
Obviously it was set up via dynamic IP. lol i get it now. lol lol 😄 😄
Primary Router:
2.4GHz Band: Channel 11
5.0GHz Band: Channel 48
5.0GHz Band: Channel 157
AP Router:
2.4GHz Band: Channel Auto
5.0GHz Band: Channel 44
5.0GHz Band: Channel 153
Looks like I need to change this. Any recommendations? I'm not a networking expert at all.
THANKS A MILLION!!!!!!!!!!!!!!
Primary Router:
5.0GHz Band: Channel 149
AP Router:
5.0GHz Band: Channel 40
5.0GHz Band: Channel 161
