KStevenson
Apr 15, 2022Tutor
R8000 Connectivity with 2 Routers
Hi Team X6 R8000 router Firmware V1.0.4.84_10.1.84 Internet speed test "Good", phone app shows 302.24 down, 23.91 up Panel lights: Power: Solid white Internet: flashing white 2.4: solid white/...
Apr 15, 2022Guru - Experienced User
Primary Router:
2.4GHz Band: Channel 11
5.0GHz Band: Channel 48
5.0GHz Band: Channel 149
AP Router:
5.0GHz Band: Channel 40
5.0GHz Band: Channel 161
KStevenson
Apr 16, 2022Tutor
Thanks Furrye38,
I did change all those settings. I was not able to change the AP from dynamic to static IP address.
It seems that for the most part all the lights upstairs generally have no problems staying connected. But at least one device drops downstairs and it doesn't matter how close it is to the router. Sometimes its more than one.
This concerns me because i want to add more devices and I should be able to given that I have 2 routers.I don't want to add a lot more devices but I would like to add more.
At what point should i consider a different/more reliable product? This thing is supposed to have good ratings.
- FURRYe38Apr 17, 2022Guru - Experienced User
What happens if you turn OFF these "lights" and then let the "one device" connect to the AP? Still see problems? Possible some "lights" could cause interference problems.
- KStevensonApr 18, 2022Tutor
FURRYe38 wrote:What happens if you turn OFF these "lights" and then let the "one device" connect to the AP? Still see problems? Possible some "lights" could cause interference problems.
I'm not sure how to cut them off except to go to the breaker box. These are light switches rather than light bulbs. There is only one that is not connecting. I've not tried all the smart plugs because they are behind desks and I'll have to go to each room and use commands. I will do that soon and typically upstairs everything works.
Question: How will turning off some switch expose an issue? Buy turning them off we can see if switches are still being dropped? I can go to the breaker box and turn off some rooms and see what happens.
Question: If there is some interference, what can be done about it?
Question: what about turning off SmartThings or abode alarm system?
Question: Would using smart connect on the AP help? (I explained my current setup in the post added to this thread.)
Thanks again!!
- KStevensonApr 19, 2022Tutor
Furrye38,
I apprepriate yoru help. I guess I'll go back to calling support. Everything seems to be up in the air with no clear idea what is going on or why. I'm becoming discouraged and looking for something more reliable. I thought since one router seemed to cover almost everything except 2 or 3 devices, two routers would double my reliability and be more than enough. But that is not the case.
If you still have some insight or some articles for me to consider. I'd appreciate it.
I notice too that my internet is buffering when i watch the news. This shouldn't be happening. I should have more than enough speed. I'm gong to disconnect the second router and see what happens. It buffers every 3 to 5 minutes. its ridiculous.
- KStevensonMay 01, 2022Tutor
I appreciate your help Flurrye, but it appears you've abandoned me. I'm also paying for phone support. I'm not getting anywhere with either.
Best wishes.
- FURRYe38May 02, 2022Guru - Experienced User
I recommend narrowing all this down and working with just 1 router and turning OFF all wifi devices that you can. Setup limited devices and see how things go with just 1 router. I use manual channels 1 on 2.4Ghz and 40 or 149 on 5GHz.
Smart Connect, Beamforming, WMM and MIMO enabled. 40Mhz only set.
If you can get to a stable operation with 1 router, then maybe start graduating adding more devices or putting a 2nd router online maybe in AP mode.
- KStevensonMay 03, 2022Tutor
Thank Flurrye for all your help. I have paid support. They were supposed to contact me in 24 to 48 hrs. I've not heard back. I'm going to returnt the equipment. I may buy a more expensive solution or go with another company. I've not decided.
Thanks! - FURRYe38May 04, 2022Guru - Experienced User
To make this a bit more simple, you may want to look in to a WIFI MESH System.
Good Luck.
