KStevenson
Apr 15, 2022Tutor
R8000 Connectivity with 2 Routers
Hi Team X6 R8000 router Firmware V1.0.4.84_10.1.84 Internet speed test "Good", phone app shows 302.24 down, 23.91 up Panel lights: Power: Solid white Internet: flashing white 2.4: solid white/...
May 02, 2022Guru - Experienced User
I recommend narrowing all this down and working with just 1 router and turning OFF all wifi devices that you can. Setup limited devices and see how things go with just 1 router. I use manual channels 1 on 2.4Ghz and 40 or 149 on 5GHz.
Smart Connect, Beamforming, WMM and MIMO enabled. 40Mhz only set.
If you can get to a stable operation with 1 router, then maybe start graduating adding more devices or putting a 2nd router online maybe in AP mode.
KStevenson
May 03, 2022Tutor
Thank Flurrye for all your help. I have paid support. They were supposed to contact me in 24 to 48 hrs. I've not heard back. I'm going to returnt the equipment. I may buy a more expensive solution or go with another company. I've not decided.
Thanks!
- FURRYe38May 04, 2022Guru - Experienced User
To make this a bit more simple, you may want to look in to a WIFI MESH System.
Good Luck.
