Ahmedyounes
Dec 01, 2019Aspirant
R8000
Is there any way I can add bridge mode to this model ?
- Dec 06, 2019
> > An R8000 is a router, not a modem+router.
> Thanks for stating the obvious! [...]
If it's so obvious to everyone that the OP has a router, and not a
modem+router, then what's the point in posting irrelevant (and
erroneous) "information" about some "Modem/Router's"?> [...] why don't you try being nice [...]
How "nice" is posting irrelevant (and erroneous) "information" here?
I fail to see how it would it be "nice" to leave such nonsense
uncorrected, to mislead the OP (and other, future readers who might be
unfortunate enough to stumble onto this thread).
antinode
Dec 06, 2019Guru
> Modem/Router's can be bridged, [...]
> [...] it means basically turning off the Wireless on the unit [...]
> so it doesn't interfer with the router's wifi that plugs into it.
"Bridge" is not a very well defined term, but normally, that's not
what it means. What it normally means (for a modem+router) is that the
whole _router_ section (not only "the Wireless on the unit") is
disabled, leaving only the modem section active.
> [...] so it doesn't interfer with the router's wifi that plugs into
> it.
And that's not the usual reason. (Avoiding multiple routers is the
usual reason.)
For an explanation of "bridge mode" for a router, visit
http://netgear.com/support , put in "R7000" as the model number, and
look for Documentation. Get the User Manual. Look for "Set Up the
Router in Bridge Mode"
But, back to the original question, ...
If it's not in the R8000 User Manual (and I don't see it there), then
I'd guess that you'd need some third-party firmware to use it that way.
I have no idea if such firmware exists.
IrvSp
Dec 06, 2019Master
antinode wrote:> Modem/Router's can be bridged, [...]
Thanks for stating the obvious! I'm sure that the OP knows this as well. So do I as I own one.
Rather than nit-picking and being rude and using snide canned responses, why don't you try being nice if you can?
- antinodeDec 06, 2019Guru
