Soldermonkey
Oct 24, 2021Aspirant
R8000P - DNS issues after firmware update
For some unknown reason, the automatic firmware update did not work on my R8000P router, and I found that I was one version behind at 1.4.1.68. So I manually updated to 1.4.2.84. After the update, ...
Apr 02, 2022Guru - Experienced User
What do you mean between .68 and .84? There was probably nothing made or developed for release between those versions so if there was, was not mented for public use.
For now, users should keep to v.68 or .v62 for now. Fixes and FW development doesn't happen over night.
canam2020
Apr 19, 2022Aspirant
Downloaded new firmware to V1.0.4.84-10.1.84 and now have the same issue on all three devices. How do I get the "old" version installed?
I am a relative novice when it comes to wireless router set up.
