Soldermonkey
Oct 24, 2021Aspirant
R8000P - DNS issues after firmware update
For some unknown reason, the automatic firmware update did not work on my R8000P router, and I found that I was one version behind at 1.4.1.68. So I manually updated to 1.4.2.84. After the update, ...
Jun 07, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Raptorialand wrote:
Can confirm setting ipv6 to automatic fixes the issue for me...
After weeks of constantly fiddeling arround with my pihole, windows software/firewall and stuff...
I thought it was a user error....
Also my alexas multiroom does not bugging out after 20 minutes now.
Everything seems to work now. Pihole works and no more reloading webpages... since 1 hour it seems to work.
kerryland
Jun 07, 2022Guide
Would it be too much for NG to produce real release notes that say what has been fixed in a given patch, rather than forcing users to guess?
