Luedi
Oct 26, 2020Aspirant
R8500 5GHz nicht schneller als 866 Mbit Client Intel 9560 160 Mhz?
Guten Tag, Ich habe einen Netgear R8500 mit der neusten Firmeware, was muss ich noch aktivieren damit ich mit meinem Client welcher eine Intel 9560 Karte hat (auch neuste Firmeware) die 1,7 Gbit ...
- Oct 26, 2020
That's just saying that Wave 2 allowed devices to use up to 160hz channels. not that they had them. its a certification.
Oct 26, 2020Guru - Experienced User
Where do you see it supports 160hz?
its supports faster speeds because of the 1024-qam modulation.
https://www.downloads.netgear.com/files/GDC/R8500/R8500_UM_4jan2016.pdf
Luedi
From the source in my 3. post.
"the performance of the Nighthawk X8 has been optimized for the Wave 2 ** ac WLAN"
** With Wave 2 technology, the radio channels expanded to 160 MHz are used
Source:
https://www.netgear.ch/about/local-press-releases/2015/2015-10-01.aspx
In all other docs not.
- plemansOct 26, 2020Guru - Experienced User
