JFII
Aug 16, 2021Guide
R8500 is it safe? FW: from 1.0.2.144 to 1.0.2.154
Checking in before i commit anyone update to 1.0.2.154? what device? what version? differences noted? Thanks!
Aug 16, 2021Guru - Experienced User
The release notes show "security fixes".
You can always install it. If it has issues, its easy enough to downgrade to the prior version
https://www.netgear.com/support/product/R8500.aspx
JFII
Aug 17, 2021Guide
Thank you.
I did read the installation/ release notes. I was looking for someone who may have some experiance with it and read my questions. If you notice I am currently on a version (1.0.2.144) which seems to have some contoversy around it. I know your answer was for those who don't bother to read the release note and then wonder what happened.
To change the subjecth here is a differet question that I may be missing the point on. Why don't (random sampling of four netgear routers. so maybe its just the ones I have been exposed to) they populate (Basic)- Attached Devices with entries from (Advanced/setup/lansetup) Address reservations or query the device for its hostname but why leave them blank when another table has been populated with the IP address, MAC address and hostname why jusy fill in a "--" . Do the devices you have worked on do the same thing?
Thanks
John
