ifixidevices
Jun 10, 2016Luminary
R8500: QOS is terrible on this $400 router
So prior to getting this router I was using a $20 off of eBay refurbished Linksys E6500 router running DD WRT (yes you can run it on that router if you know where to find the firmware for it.) Anyway...
- Jun 12, 2016
The new firmware seemed to have helped. I adjusted a few things as well and it appears to be working fine.
As for the comment of 3 figure routers and 4 figure routers there has to be some improvement over the 2 figure routers and multi-3 figure routers otherwise what's the point?
I'm trying to future proof a little which is why I picked this router. Regardless though I may just take it back and stick with my $20 DDWRT router. I don't have the latest and greatest tech (2012 macbook air and multiple iPhone 6 plus' and one room over from the router and I can't even get 60mbps through any speedtests (run it through the gigabit mac that's hardwired and I get around 65mbps every time.
I don't have a fast enough nas box at my home but I'd be curious to see wireless to lan speeds. I wonder if I can even break 100mbps with this thing...
VE6CGX
Jun 10, 2016Master
On a consumer level routers QoS don't work ideally. At the best you can do b/w limiting. If you really really need good working QoS, look into enterprise (pro) level routers which needs some steep learning curve. Consumer routers don't have enough memory and horse power to have good working QoS. After spending hours and hours, I became to realize that is the case. Also didn't you see
you lose speed ~5% when QoS is enabled? I just don't bother with it.
ifixidevices
Jun 11, 2016Luminary
The problem is with upload though. It kills my connection if there's no QOS on the upstream side. DDWRT does a really good job with it and it doesn't cost anything and you can put it on cheap routers.
I just expected a lot more out of a $400 router, that's all I'm saying.
- VE6CGXJun 11, 2016Master
dd-wrt is coming from the days of WRT-54G. There is no comparison between 3 figure routers and those of 4 figure ones. At least you can get
by with dd-wrt. I have been long retired from the field. I don't do any professional work any more. Just anything at consumer level devices can't
meet the expectations of some folks. It is like expecting Honda Civic drive like a Porsche McCan, LOL!...
- ifixidevicesJun 12, 2016Luminary
- VE6CGXJun 12, 2016Master
Of course between a guy driving a Chevy and Porsche, what's the difference? "A car is a car. Purpose is to go from point A to point B" Of course that is true. How can I argue. QoS is not on my priority list. Without it my network works just fine. No users have any complaints in the house. Main thing is having fun wharever one does.
