Nuforce
Nov 20, 2023Aspirant
R9000 Nighthawk X10 Router SFP internet port question
 Hi     I want to be able to use the X10 as a bridge to connect to my existing wireless network. I also want to connect a device I have to the router via the SFP port.     Will the SFP port output acc...
Nuforce
Jan 09, 2024Aspirant
ok so I've just received a pair of Finisar FTLX1471D3BCL which are confirmed as compatible with the X10 and I still can't get the SFP connection to work.
The 10G light is not illuminating and my connected device isn't seeing the X10 over SFP.
Do I have to enable SFP in the admin area somewhere?
schumaku
Jan 09, 2024Guru - Experienced User
Where it the other end FTLX1471D3BCL SFP+ connected to? Computer fiber adapter or switch, make, model, firmware, ....?
Correct Single Mode Fibers in place?
LC/PC or LC/UPC connectors on the patch cord, typically blue (not green ... that would be LC/APC)?
Both FTLX1471D3BCL marked for the same wavelength? 1310 nm is a typical default.
Crossed tx and lx fibers accordingly?
A generic module with an RJ45 port for copper Ethernet is often helpful in checking the SFP/SFP+ ports.
