CPY1048454102
Mar 15, 2019Star
R9000 Resets on Reboot
Hey guys,
I upgraded my router's firmware to 1.0.4.28 today (was 1.0.4.26 before), and it now keeps reset the whole setting everytime after rebooting the device. I can't even restore my settin...
- Mar 16, 2019It also did the same thing to mine, an hour and 26 minutes later with Berger’s tech support and then making me do a reimage and reset on the router 3 times over the phone (yes I tried all that before I called including downgrading also) they finally decided they would RMA this one. It ran perfectly fine on 1.0.4.26 but this upgrade trashed something internally and there doesn’t seem to be any coming back from it. Good luck!
CPY1048454102
Mar 19, 2019Star
I don't know if I understand your words correctly, since as long as your 180-day hardware warranty is not expired, you may get yours replaced like we did, you can go to your user's homepage, click "My Support" on the left, choose "CONTACT SUPPORT", then choose "Get help on my NETGEAR product", fill in the details and they will give you a case number and tell you to call them within 24 hours. Then you just call the number they provided and give them the case number you just got, you need to tell the agent that you upgraded the firmware to 1.0.4.28 and now has the problem, it was fully functional. When the agent want to do some uncessary troubleshooting thing (like flashing different firmware versions), you can tell him you tried and that didn't work, so he probably wont waste you too much time on that. If you are lucky, after 40 minutes or so, he will probably "have tried all the possible solutions" and finally ask his supervisor for RMA Approval. Then they will send you an email for RMA instructions.
I didn't know we have this hardware support that can get things RMA'd until acydfyre told me that. But I'm completely agree with you that this firmware update is ridiculously unreasonable, they even have this firmare on their website by now (Mar. 19). They really need a lesson on "responsiblity".
fercho1974
Mar 20, 2019Guide
There seems to be a good amount of us here having issues, many i presume out of warranty periods. So, if this did compromise the storage, where does that leave us? And does Netgear monitor the community?
I feel like this is the WORST $400 ive spent on device, and this is already a newly RMA'd router. Less than 6 months. But, since they go by original purchase date, warranty (90 / 180) doesnt apply to me. Linksys/Asus time?
- acydfyreMar 20, 2019StarI agree it’s a huge hassle and this is also my second RMA’d r9000, the first had 5g antenna failure. Best thing we can really do is complain complain complain and try to get them to respect the consumer. It’s apparently not happening to every ones router but between this thread and a couple others I’m on, there are a LOT of people with devices with this issue. I switched to netgear equipment from linksys a few years ago because linksys was always having problems but it may be time to try out asus.
- CPY1048454102Mar 20, 2019Star
I honestly don't know, bro. I'm not feeling happy that I got my router RMA'd, they should have made it perfect considering its top tier price tag. I bought this router because I want to experience fast, stable wifi and NAS transfer for 2, 3 years or longer, until a new revolutionary wifi standard comes out. But it has only been three months and now we are having this issue. I am the lucky one since mine is still relatively new and under warranty, but for other people it's like $400/yr renting a router or basically tossing money into river. I think I would also choose ASUS or other brands next time, and definitely not Netgear.
- fercho1974Mar 22, 2019Guide
Copied from a different post in the community, posted by zipperhead:
1. You may try this link for the hard reset: https://www.lifewire.com/hard-reset-rule-for-routers-3971318
2. Try to re install again the router and put the put the configured settings.
3. Reboot device after.I will try this and hopefully this works.
