miztrniceguy
Oct 19, 2021Aspirant
RAX40 throttled on wifi and LAN
I have a Nighthawk RAX40. I just moved and am not getting the speeds I should. At previous address about 2.5 miles away I had the same internet package with Spectrum for 400Mbps and consistently got ...
Oct 20, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
miztrniceguy
Oct 20, 2021Aspirant
Thanks for the lunk. I will post over there. So frazzled trying to gwt this worked out. Had to resort to a lesser router in the meantime
- FURRYe38Oct 20, 2021Guru - Experienced User
đ
