samfromco
Oct 11, 2020Guide
Re: R7960P firmware not upgrading
Unable to upgrade the firmware, using webconsole or uploading manually. Customer support doen't stand behind their product quality. And belittles their customers. So pathetic, Netgear lost me as a c...
- Nov 02, 2021
Was able to flash to latest firmware version using nmrpflash.
Please take a back of the config before using this utility.
https://github.com/jclehner/nmrpflash
Original solution:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/TFTP-Issues-Bricked-R6700v2/m-p/1974041/highlight/true#M168281
MarkSparks
Jul 14, 2021Aspirant
So this issue has been reported here and languishing for almost a year now and there is COMPLETE RADIO SILENCE from Negear. This is unbelieveable to me. I am sure they monitor this forum but do not want to have to answer the question "Why isn't Netgear fixing this problem?!"
It must be a "hardwired" problem that they don't want to have to issue a recall of the units to fix. They are leaving it to us to "eat" their mistake. Unbelievable!! At least there are other good manufactures of routers and switches out there. No more Netgear junk for me!!
PalmSpringsBill
Jul 14, 2021Tutor
I am with you 100% and won't buy another Netgear modem/router after this... but is your router still working? Mine still provides strong internet access so takes some of the sting away.
What exactly did the firmware upgrade do?
