gapcdr
Dec 30, 2020Aspirant
Re-register a used device
I purchased a used WAC124 on eBay and cannot login because it says "This WAC124 is not registred for the current user, please login with the registred user.". How do I get this unit moved over to me? I have been able to configure the device by disconnecting it from the internet and it gives me a local login.However, this is not a workable solution going forward.
- No1MportntLuminary
Here is a link to the User Manual for that device. It may have the information that you need.
https://www.manualslib.com/manual/1553297/Netgear-Wac124.html
- gapcdrAspirant
Thanks but I already had the manual and it doesn't help. The manual is written for a new user that has registered hie router with Netgear. I am the second user and do not know the User Name/Password that the device is registered with. I need to get it registered to my account.
> Here is a link to the User Manual for that device. [...]
When looking for a manual for a Netgear device, rather than start at
some third-party web site, I'd suggest starting at the Netgear support
site:Visit http://netgear.com/support , put in your model number, and look
for Documentation.If that fails, _then_ I'd start a broader Web search.
> [...] had the manual and it doesn't help. [...]Have you tried contacting Netgear support? Or looking/asking on the
appropriate forum?:https://community.netgear.com/t5/x/bd-p/business-wireless-for-business
> [...] I have been able to configure the device by disconnecting it
> workable solution going forward.A while ago, when questions about that device first started appearing
here, I took a quick look at its User Manual, saw that it was almost
useless on its own, and decided that I was unlikely ever to buy one.
