Bill-D
Oct 06, 2021Apprentice
Remote Management missing in R7000 after upgrading to 1.0.11.128
After upgrading from '126 to '128, my R7000 "Remote Management" features disappeared. Under the Advanced/Web Services Management tab, the checkbox, "Turn Remote Management On" and everything belo...
noglider
Mar 09, 2022Aspirant
I'm very annoyed. Can we expect a response from Netgear?
Bill-D
Mar 09, 2022Apprentice
My R7000 is on v134 and its been stable but I still miss remote management. It would be nice if Netgear, as least, explained why it was removed.
- FURRYe38Mar 10, 2022Guru - Experienced User
ttps://kb.netgear.com/000062097/Remote-Management-is-now-Anywhere-Access-in-the-Nighthawk-and-Orbi-apps
- nogliderMar 10, 2022Aspirant
I can access my router from the outside using the nighthawk app. But I can't do everything. I need to work on port forwarding when I'm away. I can't. This is reduced functionality. This is not satisfactory.
I recommend installing a remote control app like Remote Desktop or TeamViewer if you need full access and controls.
