Batman-15
Dec 16, 2021Tutor
Remove a Device from the Allowed Access List
Good Morning: I really need some help with the following issue: When I go to > Security > Access Control > Allowed devices Currently not connected the network and try to remove a device from by the ...
DexterJB
Jan 17, 2022NETGEAR Moderator
Thanks for responding. We'd like to know the following.
1. Does the issue persist with other firmware versions?
2. Have you tried using a different browser/device?
3. Have you tried modifying the setting using Incognito Mode/Private Browsing?
4. Have you tried disabling browser extensions (AdBlock etc.)?
Dexter
Batman-15
Jan 17, 2022Tutor
Bottom line up front I've tried all your suggestions the issue still persists.
OK Here are the final answers to your questions:
Q. 1. Does the issue persist with other firmware versions?
A. Yes, this issue has persisted through all firmware revisions.
Q. 2. Have you tried using a different browser/device?
A. Yes and I tried both Safari and Firefox the issue persists.
Q. 3. Have you tried modifying the setting using Incognito Mode/Private Browsing?
A. Yes I tried a "private" window with both Safari and Firefox, the issue persists.
Q. 4. Have you tried disabling browser extensions (AdBlock etc.)?
A. I have no ad blockers installed.
- abextraJan 21, 2022Aspirant
So It sound like installing Bata Test v1.3.3.142_10.1.75 Hot Fix on my Night Hawk R6900P is not worth doing maianatnce purposes, anyone recomend a firmware?
Thx.
Batman-15 wrote:Bottom line up front I've tried all your suggestions the issue still persists.
- Batman-15Jan 22, 2022Tutor
That is the same patch/hotfix I have had on my router since it was released.
- abextraJan 22, 2022Aspirant
Thanks for the reply Batman
The installed firmware now is v1.3.2.134_10.1.66 and when I had the router check for updates all I got was an icon for free 30 day trial of Armor Security ! Just what I dont need is my phone screwed up by netgear unfinished code. Sounds like moving to Firm v1.3.3.142_10.1.66 hotfix could be just trading one problem for another. I'll have to seek out more info.. Now I need to get that Armor Icon off my router.
