Sarge34
Apr 05, 2021Guide
Reset password and user name on www.routerligin.net
I purchased a Netgear R8000 router that was used. I was able to register it wtih Netgear and I want to see if I need to upgrade the firmware. I go to www.routerlogin.net and found the default user ...
microchip8
Apr 17, 2021Master
There's a Reset button at the back of the router. Push it in for 5-10 seconds and release
Sarge34
Apr 17, 2021Guide
Thank you for your reply... I have reset the router but it won't reset, http://www.routerlogin.net/. The former owner set their log in at the website and I can't get in touch with the former owners.
- microchip8Apr 17, 2021Master
After a reset, the default password should work. The default is "password" and username is "admin"
- michaelkenwardApr 17, 2021Guru - Experienced User
Sarge34 wrote:
The former owner set their log in at the website and I can't get in touch with the former owners.That does not make sense. There is no "website" where anyone can set a passwords. So the previous owners won't have done anything that you cannot reverse with a reset.
It is a mistake, and confusing, to think of www.routerlogin.net as a "website". It is actually just a way into the browser graphical user interface (GUI) for your router. It goes nowhere near the internet. You can even use it without having a connection to the outside world.
As microchip8 says, the reset button should get you back to square one. If that doesn't work for you, we need more details of what you are doing and where things go wrong.
- Sarge34Apr 17, 2021Guide
You are so correct. It is very confusing and makes no sense. I'm confused what you are trying to say as I can't make sense out of it. YOu wrote, "There is no "website" where anyone can set a passwords" I'm not sure what you mean when you say "where anyone can set a passwords" What are you talking about when you say "passwords" as in plural? Are there supposed to be more places to enter them? You also typed, "So the previous owners won't have done anything that you cannot reverse with a reset." What do you mean previous owners won't have done? Please clarify. Thank you for responding.
- michaelkenwardApr 18, 2021Guru - Experienced User
I'm sorry about that, but there are some things that take a bit of understanding. Eventually, you have to do some homework and not expect people to explain things over and over again.
Did you try the advice that microchip8 suggested? That would be a good place to start.
It means what it says.
You seem to think that there is a website somewhere that the previous owners have created some passwords. There isn't. The rest follows. If there is no site on the world wide web, there is nowhere out there to reset passwords. You do that by following the advice from microchip8
Have you done the basics? Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.
You may have done this already. I can't tell from your message.
Netgear makes life interesting by having all manner of passwords. There is the one into the router's controls, then there are those to get into the router's wifi, and then there any that you use to get into this Community and/or MyNetgear.
Different passwords pop up at different times, depending on how you connect to the device and where you are trying to access from, your local network or somewhere else on the Internet. (Previously known as Remote Access, that's now called Anywhere Access.)
If you are talking about access to the browser's graphical user interface (GUI), the router's controls, these are on the label for your device, along with the default wifi login details. The username is fixed at admin. The default password is password.
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. (See above.) Then either disable password recovery (check the manual for your device) or provide some answers to those questions.
