Tamumiket
Apr 13, 2024Aspirant
Router does not support https protocol R9000 Nighthawk
Some time after I purchased the R9000 router the https protocol stopped being supported and I may only access the admin interface via http Are there any suggestions to restore https access to th...
microchip8
Apr 13, 2024Master
Enabling HTTPS on the router does not mean it's globally available to the LAN/WiFi. It's only for the router's web interface so login credentials are encrypted.
Tamumiket
Logging on to the router with https as admin is what I’m looking for.
I cannot find the option in the admin web interface to enable https to connect to the router
