packerbacker12's avatar
Dec 07, 2017
Router download speeds are slow on Nighthawk R8000
I just recently switched to Spectrum here in WI. My download speed when connectly directly to the Spectrum provided modem is 108MB. When connect any of my devices to the route,r either wireless or ha...
  • michaelkenward's avatar
    michaelkenward
    Dec 08, 2017
    Things that people have tried to fix the "router is throttling my modem" issue with various devices:
    • Ensure that the cable from the router to the modem is up to the job
    • Check that you have the latest firmware (and "factory reset" the device)
    • Check that you have the right internet settings for your ISP (especially MTU)
    • Turn off QoS
    • Turn off the Traffic Meter
    Netgear also advises that you should turn off QoS if you are on Gigabit Internet. You don't need it.
