cmartorelli
Mar 07, 2020Guide
Security flaws if only used as access points
I have read the recient artical about the vulnerability with netgear routers. I have two netgear R7000 running older firmware V1.0.9.42_10.2.44. I do not upgrade because every newer verson of firmwar...
- Mar 09, 2020
Greetings,
See the following link...
https://www.netgear.com/about/security/
Scroll down a little bit. It shows all of the security advisories, models affected, and the minimum version of FW required to be protected.. In the case of the R7000, 1.0.9.42 has protection against the recently discovered exploits.
cmartorelli
Mar 09, 2020Guide
I am the original poster. I am sorry for all the typos on my first post, my phones auto correct took over. In regards to the vulnerability with netgear routers, do I need to worry if I do not use my night walks as routers? I just used them as access points. They are two netgear R7000 running older firmware V1.0.9.42_10.2.44. I have an Edge Router X, all my traffic is going through the edge router first.
Thanks
shadowsports
Mar 09, 2020Hero
Greetings,
