chilli_T
Aug 25, 2024Tutor
Setting up fiber bridge between Netgear routers
This is another one of those “setting up a network, need some help, and I’m a bit ignorant” posts. I was referred to the Netgear community from a reddit post. I know this isn't quite the right forum ...
- Aug 26, 2024
Would not be any grounding issue between buildings since LAN doesn't have power running thru it. Also if cabling is done right, would work for CAT6A STP cabling which would be recommended.
