jetguat's avatar
jetguat
Tutor
Jan 09, 2022
Synology DS918 access only via ipAddr instead of Hostname using ORBI
I have a Synology DS918 network shared on my home network.  its connected via ethernet. I have an ORBI system that provides the wifi to the house. The two desktop PCs are conencted to the etherne...
  • jetguat's avatar
    jetguat
    Jan 09, 2022
    The solution - thanks for the assistance - was to setup the ORBI into the Access Point (AP) operational mode.  I could not figure how to tod that initial, as I was unable to access the orbi directly.  Once I accessed the ORBI via a mobile browser connected on the same network via wifi, then I was able to get into the configuration and change the operational mode.
    all is well.  Thanks for the help and assistance
