TXTornados
Oct 30, 2017Tutor
VPN on R7800
Like the other thread, I want to use my router as the VPN client, I do not want to have it loaded on the individual devices (IOS, Android, MAC and Win). Reviewing the discussion, I was going to try ...
- Oct 31, 2017Yes a tftp flash from command prompt is all that’s needed to revert to stock, in fact stock firmware settings are still saved when you revert.
avtella
Nov 02, 2017Prodigy
LEDE is more stable also has SQM QoS. DD-WRT is not bad but LEDE stable version is more bleeding edge and seems better on this device. I believe DD-WRT is still using the older 3.X kernel.
Nooneshere
Nov 02, 2017Aspirant
I also tried Davidsc502 on my linksys and wasn't that impressed, like I say to each their own.
