Randin
Jan 11, 2018Aspirant
Warm Reboots vs Power Cycling
From my understanding it's bad for chips to change temps regularly... i.e. turning off a router at night, then turning it back on in the morning. The chips go from hot to cold, back to hot... and ove...
- Jan 12, 2018
Randin wrote:Thanks, but I apparently obscured my question by providing too much background info as to why I wanted to do a warm reboot each morning. Again, the question wasn't about turning wifi off (which I know is fine), or about a cold boot (which I am not doing).... it was about a daily warm boot.
Instead of providing so much info I should have just asked:
"Is a daily warm boot ok, or will it wear the router faster?"
Since your wanting too do a warm boot the hardware should be ok , The firmware is should load correctly as long no issues pop up during the booting process is the main danger I can see. Your just reloading the os(firmware) like you would in a computer with a reset(reboot) button.
Randin
Jan 12, 2018Aspirant
William10a
Jan 12, 2018Master
