tedio
Sep 14, 2018Tutor
Where can I change the user name admin?
- Sep 15, 2018
> [...] I don't see how to add a user to use instead of admin. [...]
Netgear doesn't provide a way to do that.
> [...] I am concerned with security. [...]
Ok. Please explain how a different user name would improve security
more than using a longer password.
tedio
Sep 16, 2018Tutor
You already know the answer to that but I except your answer. Only wish they would add the feature in a future release. Thank you for your reply.
William10a
Sep 17, 2018Master
I agree being able to change the admin name would close off an entry point on your network but untill the firmware allows it we are sick with the same issue.
- schumakuSep 17, 2018Guru - Experienced User
No, it would be just security by obscurity. Like the heroes moving the default ports to other random port numbers.
