kneel242
Apr 17, 2022Aspirant
Re: Why my router jumped to a wrong time (R8000)?
Well I am on V1.4.2.84_1.3.42 I noticed 1.4.3.88_1.3.50 is available so I will update but still. NTP wasn't broken was it? Can't find any actual release notes for their updates, netgear's "Securit...
Apr 17, 2022Guru - Experienced User
I noticed 1.4.3.88_1.3.50 is available so I will update but still. <FYI, this version of FW is for the R8000P, not the R8000.
NTP wasn't broken was it? Can't find any actual release notes for their updates, netgear's "Security" page is super cryptic god only knows what is being rolled out in each individual update.
I have the NTP secton configured currently for Netgear's NTP services now because no external NTP works at all when i try it.
not only that, so lets say its on netgear's NTP servers, and time is synced. Whenever I try syncing to any external NTP provider it ust errors saying it won't work but it also then changes the time to be about -40 minutes off.
Like why wouldn't it keep its last known synced time rather than changing to a random time? its not like it got that other time from anywhere it literally won't connect.
kneel242
Oh haha yup thanks, I do have the R8000P.
And even after the firmware update I'm getting same error when attempting to switch to an external NTP server. Weird
"Warning: The Router failed to connect to NTP server, please check your Internet connectivity or try another NTP server"
It's not a big deal I am fine using Netgears NTP for now but I had noticed somehow my timezone got changed so I was attempting to switch it to external. Also because I've been having issues and needing to reboot the R8000P every so often, wifi and all connectivity just dies on it.
I'm sending all logs now so will keep a closer eye on whats going on when everythings drops offline randomly once every week or month or so
- FURRYe38Apr 17, 2022Guru - Experienced User
I recommend a factory reset and setup from scratch after loading FW.
