kneel242
Apr 17, 2022Aspirant
Re: Why my router jumped to a wrong time (R8000)?
Well I am on V1.4.2.84_1.3.42 I noticed 1.4.3.88_1.3.50 is available so I will update but still. NTP wasn't broken was it? Can't find any actual release notes for their updates, netgear's "Securit...
nnagreg
Apr 18, 2022Apprentice
Yes, I had the SAME time problem, it appeared someone changed my NTP settings.
Which prevented my system from AUTO UPDATING to the latest FIRMWARE.
Once I updated the the correct time, the router was able to see that I was several revisions old with my Firmware Updates.
I had to do a factory reset after the update and refresh the entire configuration.
Hope this helps!
