bmgarcia
Sep 05, 2017Tutor
X6S Extender - Extended placement
If I buy this extender where do you suggest i place it? My router is set up in the main office towards the front of the building. Should this be set up in the middle or towards the back?
- Sep 06, 2017
Positioning of extender within the home depends on the layout, where your router is and how good your router is etc. On Nighthawk X6S, there are intelligent LED indicators which will guide you to place it in the best position. You can take a look at the Quick Start Guide that comes with the product for more details on how the led's help you with it. It's pretty straighforward. To learn more, please visit http://www.netgear.com/landings/ex8000/
stjannifer
Sep 06, 2017Aspirant
Place Range Extender Maximum 25 meter From Main Router... for good working...and for more details checkout mywifiext
- antinodeSep 06, 2017Guru
> If I buy this extender where do you suggest i place it? [...]
Which "this extender"? It would be practically impossible for anyone
here to know the optimal location for a wireless device in your "the
building". Run the experiment, and see how well things work with the
hardware in different configurations.
