jwannemuehler's avatar
Jan 01, 2022
Yellow Ethernet light
I plug my ethernet into my computer and the light flashes white. I plug the same ethernet into my TV and it turns yellow/amber. The TV registers the ethernet connection, but seems super slow. Any sugg...
  • nielsvds's avatar
    Jan 02, 2022
    That is to show the difference that the ethernet port is working with 1000 Mbps (1 Gbps) or only 100 Mbps. That totally depends on what network card is inside your device that you connected wired. Smart tv's doens't have gigabit (Gbps) ports yet.
