RogeRoje
Feb 13, 2017Follower
Ready Cloud Folder Not Available
Currently I am using a R7000 Night hawk Router. I have a ready cloud account and WD 1 TB external Drive connected. The folders are simply not showing when I log into ready cloud. I can see the volume...
- Mar 02, 2017
Hi RogeRoje,
Try to reset the router and reconfigure. Check again if the same. My R7000 is working with the ReadyCloud.
JamesGL
Feb 15, 2017NETGEAR Employee Retired
Hi RogeRoje,
Unregister your account from the R7000 and try to re-refister. Check if still the same. Make sure the router is on the latest firmware. Reset and reconfigure.
