Tuaha's avatar
Tuaha
Ready cloud Register the usb hardware not working
So i am trying the register my usb drive with redycloud but no luck. i read many threats on this side but no have the solution.
i can log in to https://readycloud.netgear.com but every time i do that i got the following message
Currently you have no registerd or shaer drive
balabalabala
so i go to my router admin account and try to register
every time i put the username and password it tell me your username and password is not correct.
i talk to the costomer support and there answer is, you pass your 90 days warenty so they can not help unless i buy the tec support servise.
i already try the following
reset my router with new and old firmwear
creat a new account and still no luck
I am not suer what ells i can do
I have this service working for last 2 years but because there IOS app dosent work very welli have to unregister the drive to register backso that i can use the ready clod app
But that is my biggest mistake
Any help will be really appreciated
Thanks
