Cold0179
Dec 14, 2022Follower
Ready share cloud
I'm running a Nighthawk R7900P and my router usually works with my drive on it. I can see it when I am at home and my ready cloud works while on the network. I'm out of town so when I go to tap into m...
michaelkenward
Dec 14, 2022Guru - Experienced User
Cold0179 wrote:
I am using it as an APN bridge because the modem is a a dual model modem/router provided by my ISP.
What does APN bridge mean/ Modem only?
What is this dual model modem/router?
Don't get hooked on ReadyCloud. It is on its way out.
Support for ReadyCLOUD feature ends spring 2023 | Answer | NETGEAR Support
