Graymayre
Dec 17, 2020Follower
Ready SHARE with USB 3.0 is very slow
I purchased this router for this particular feature, which I did not attempt to implement until now. I have tested with various firmware versions, including the September 2020 version. Consistent p...
Dec 17, 2020Guru - Experienced User
there's a difference from read to write speeds with these routers. Its cpu limited. Its also why the r9000 has faster speeds, its several years and generations of cpu newer.
Its a nice feature to have but if you're wanting peak speeds, I wouldn't be using a router for it.
And its not just a "netgear issue". Its an issue of using a router as a NAS. this applies to other manufacturer's as well. They just aren't NAS's.
Here's a chart that goes over some of these. (you can change the charts for whatever storage method and read vs write you want)
https://www.smallnetbuilder.com/tools/charts/router/bar/174-ntfs-write-usb-3-0
And one just for the R7000P
you can try getting in contact with support but it isn't going to get you anywhere because it isn't a hardware failure. Its a failure to understand expectations of using a router as a NAS.
