PCChan
Dec 11, 2020Guide
ReadyCloud Andriod backup with broken pipe error
ReadCloud Andriod version: 2.0.7 Andriod mobile: Samsung U20 android verison: 10 R7800 Firmware: V1.0.2.78 Seagate backup plus portable drive 2Tb plug in to router USB port It used to work wel...
- Nov 02, 2021
ReadyCloud version 2.1.1 is finally fixed the problem... I've upgraded the app in my phone. Backup is finally worked after over a year using manual backup.....
DarrenM
Dec 17, 2020Sr. NETGEAR Moderator
Have you tried to revert the firmware and see if it starts working again?
DarrenM
PCChan
Dec 19, 2020Guide
Hi Darren,
I tried downgrade to firmware version V1.0.2.68. ReadyCloud android app backup works well. All subsequent version up to V1.0.2.78 (the current version). Same error is reported. It's related to the firmware.
I appreciate your suggestion and possible solution to resolve this issue.
Frewin
