PCChan
Dec 11, 2020Guide
ReadyCloud Andriod backup with broken pipe error
ReadCloud Andriod version: 2.0.7 Andriod mobile: Samsung U20 android verison: 10 R7800 Firmware: V1.0.2.78 Seagate backup plus portable drive 2Tb plug in to router USB port It used to work wel...
- Nov 02, 2021
ReadyCloud version 2.1.1 is finally fixed the problem... I've upgraded the app in my phone. Backup is finally worked after over a year using manual backup.....
DarrenM
Dec 17, 2020Sr. NETGEAR Moderator
Have you tried to revert the firmware and see if it starts working again?
DarrenM
sabinus
Jun 10, 2021Aspirant
DarrenM so the official workaround is to revert to an older firmware and possibly compromise security instead of Netgear fix a long standing broken functionality?
- PCChanNov 02, 2021Guide
- FURRYe38Nov 02, 2021Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerEnjoy. 📡
