JSTAMP
Apr 20, 2022Aspirant
ReadyCloud App not installing properly
Having an issue with the ReadyCloud app where it no longer appear in the system tray (Windows 10). Can re-install app and it appears above the system tray, but as soon as you click into a share, it opens the folder window but the navigation pane above the system tray disappears. right disappears. If I try running the application from the Netgear folder, nothing happens. Run the process on a separate machine and it's fine and no other users reported an issue.
No RepliesBe the first to reply
