jsguy16
Feb 21, 2016Aspirant
ReadyCloud does not show folders or files on USB drive
Router is R7000 Firmware V1.0.5.48_1.1.79, Windows 10, Chrome Browser. Have tried unregistering and re-registering. Have same issue with ReadyCloud desktop app.
- Feb 05, 2017
Hello JamesGL,
I have an R7000 router and had the same issue as the other posters here.
Updated to the latest firmware and all file are now accessible.
Thanks for the tip.
dmanduff
Aug 18, 2016Aspirant
I'm having the exact same problem as well.
- JamesGLAug 22, 2016NETGEAR Employee Retired
Hi dmanduff,
1. What is the firmware version of the router?
2. Was it working before?
JamesGL
Community Team
- DusssAug 25, 2016Aspirant
Hi JamesGL,
My R7000 has the same problem as described by xmirobruix. I can access the drive via the pc and see everything on it, but trying to access via Readyshare results in the same screens that xmirobruix has posted and I cannot access any folders/files via the app on the phone or desktop or the webclient. The current firmware is 1.0.4.30. I've tried a factory reset and then let the router configure, but no joy. Any assistance would be greatly appreciated.
Also, the USB harddrive does not spin down at all when connected to the USB port on the router, but while connected to the pc it will spin down after 5 minutes or so. Is there anything I can do to change this?
Kind regards,
Dusss
- JamesGLAug 28, 2016NETGEAR Employee Retired
Hi dmanduff,
Make sure you are done with the migration for ReadyCloud. Check the link below.
http://kb.netgear.com/app/answers/detail/a_id/30671/~/readycloud-to-mynetgear-single-sign-on-faq
Please update the firmware of the router.
https://www.netgear.com/support/product/R7000#download
JamesGL
Community Team
