vge
Dec 01, 2021Aspirant
ReadyCloud on R7960P stopped working when is placed behind another WIFI router
The ReadyCloud on my R7960P works fine if I connect the R7960P router directly to my cable modem. However it stops working if I placed the R7960P router bebind another router, in which case the inter...
Dec 01, 2021Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Try connecting the R7960P to the upstream router usnig the WAN port, not the LAN port.
Try putting the R7960P WAN IP address it gets from the host router, in to the host routers DMZ.
