vge
Dec 01, 2021Aspirant
ReadyCloud on R7960P stopped working when is placed behind another WIFI router
The ReadyCloud on my R7960P works fine if I connect the R7960P router directly to my cable modem. However it stops working if I placed the R7960P router bebind another router, in which case the inter...
michaelkenward
Dec 02, 2021Guru - Experienced User
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
How to fix issues with Double NAT | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
vge
Dec 02, 2021Aspirant
Thank you guru FURRYe38 and michaelkenward for your quick response.
The reason I want 2-router setup: I need both ReadyCloud and mesh WIFI. However none of Netgear's mesh WIFI supports ReadyCloud yet.
I need ReadyCloud USB storage access, mesh WIFI for btter WIFI coverage and speed.
Please let me know if you know better solution.
THANKS
- FURRYe38Dec 02, 2021Guru - Experienced User
Try connecting the R7960P to the upstream router using the WAN port, not the LAN port.
Try putting the R7960P WAN IP address it gets from the host router, in to the host routers DMZ.
THANKS
- michaelkenwardDec 02, 2021Guru - Experienced User
Me too. Here's how I do it.
R7800 is router with ReadyCloud enabled.,
Orbi Mesh system in wireless access point mode.
Works a treat.
Using one router behind another, Mesh or otherwise, with one in AP mode, could still deliver ReadyCloud through the one in router mode. It does here.
Wifi on the Orbi AP gets through to ReadyCloud on the R7800.
But I can see no Mesh devices on your network. Unless they added it with fresh firmware, the R7960P doesn't do Mesh. And putting two of them together is not the same thing.
