jamespusateri
Jul 01, 2016Aspirant
ReadyCloud problem
I have a R7000 and ReadyCloud is not working with my external HD via the application or web portal. It has worked in the past. When I try to browse, it just toggles back and forth between the router ...
- Jul 13, 2016
Yes I did. The app seems to be working now.
jamespusateri
Jul 13, 2016Aspirant
JamesGL
Jul 14, 2016NETGEAR Employee Retired
Hi jamespusateri,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
