woedee
Jul 03, 2017Follower
ReadyCloud Setup on R9000 - Not Workng
I'm trying to setup ReadyCloud on my R9000 (Advanced>Readyshare>ReadyCloud); however, when I do that, I get the following message:
"You are currently logged in from another device. There can be only one device logged in at a time. If you log in from this device, the other device will be logged out. Do you want to proceed?"
I select "Yes" but then this just takes me back to the main routerlogin.net menu/homepage, so I'm stuck in a perpetual loop here. I am not logged-in form any other devices, so I don't know what is going on here. My R9000 is on the latest firmware (1.0.2.32). I have already rebooted the router several times & tried multiple web browsers but still does not work. Any suggestions?
Hi woedee,
Try to clear the cache of your web browser.
Use a different web browser.
If still the same, use a different computer.
