juljan's avatar
juljan
Readycloud setup
Hi, this is not a new question, but from what I read on the forum, I have not found a solution to my problem.
I have a netgear account went to http://readycloud.netgear.com/client/en/router-setup.html to make a readycloud account. when i go to http://routerlogin.net as instructed it comes up saying 'Currently you have no registered devices'.
When the login box comes up I have tried entering the netgear account details but nothing happens. any help would be greatly appreciated!
Many thanks,
Juljan
1 Reply
  • michaelkenward's avatar
    michaelkenward
    What Netgear device do you own? Is it registered in MyNetgear?
    https://my.netgear.com/myNETGEAR/myProducts.asp
    Is the Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0 listed in your footer involved in this in anyway? Or did you just click the first thing that popped up when you wrote your message?
    The A7000 isn't something that normally has anything to do with Readycloud.
