hampal
Aug 27, 2021Aspirant
ReadyDLNA problem - pictures incorrect orientation
When connected to ReadyDLNA all pictures display in landscape orientation even if they are supposed to display in portrait. If I connect to the same ReadyShare drive wih SMB/CIFS they show in the cor...
hampal
Aug 28, 2021Aspirant
It's actually a c7000v2 but that wasn't an option on the dropdown. ReadyDLNA and ReadyShare are definitely features of this router/modem. What I don't get is how the same picture displays correctly on the same client when using Servio or plex as the DLNA server, but copy it to readyshare and display it through ReadyDLNA and it's sideways. Same thing happens with some videos.
michaelkenward
Aug 29, 2021Guru - Experienced User
The answer is to include key details in the text of the message.
No matter, I see no sign that the c7000v2 supports ReadyDLNA. ReadyShare is something else.
The only cable modem/routers that do promise ReadyDLNA are the C6250 and the newer CAX30 and CAX80.
Then again, this would not be the first time that the manual had things wrong.
The good news is that if a cable modem router does support something, there won't be newer firmware that wipes out features, which has happened to some routers. Netgear cannot change the firmware on a cable modem.
