AvaneeshBajoria's avatar
Sep 03, 2021
ReadyNAS 31600 Booting problem; system hangs when booting reaches 99%
We have a Netgear ReadyNAS Model 31600.  This morning the device booted but at 84% it got stuck.  It stayed so for about an hour, thereafter I restarted it manually.  by hard pressing the power button.  After restarting, it progressed till 99% and then again got stuck and stayed so for another hour.
I am not able to access the device over the network through its designated IP.
Any suggestions would be appreciated.
Thanks.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    As the nae says, the RN31600 is a ReadyNAS device. You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    ReadyNAS Network Storage: Official NETGEAR Community
    There is not much on common between ReadyNAS and the router covered here.
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
